Activity Forums Avid Media Composer HELP!! running AXP on an Opteron X2 system
  • HELP!! running AXP on an Opteron X2 system
    Posted by Rodman on May 15, 2007 at 3:11 am
    First of all, I work most in After Effects… but I also work with Avid Xpress Pro HD.
    I’m about to buy a new system… I want a realy powerfull equipment. My question:
    1.-Does Avid Xpress Pro HD, work with a multiprocesor system?
    2.-Does Avid can run on a AMD Opteron (dual core) system?
    3.-Do you know if there is a way to run Avid Xpress Pro HD on a 64bit OS (does Avid is planing to realese a 64bit version of AXpro)
    4.- Wich System do you recomend me.. Xeon or AMD
    I want to buy a tow Opteron 4Gb ram system to use it for composing.. but I also use AXP….
    any recomendation and expirience will be apreciated!!!
    thanks… good vibes
    Jhones replied 19 years, 4 months ago 3 Members · 2 Replies
  • Michael Hancock
    May 15, 2007 at 3:48 am
    Buy an HP xw8400. It’s a certified system for Avid, which means you’ll get help if you need it, and it’s a beast so you shouldn’t have problems with your compositing. Go to http://www.avid.com and check out the products page for system specs.
    If you do go with a non-certified system–people have had trouble with AMD, Avid is not 64 bit and who know when it will be–stay away from ATI video cards. nVidia only. Good luck!
    Michael.
  • Jhones
    May 17, 2007 at 8:31 am
    from my experience with AMD and Avid the results r quite bad specialy if its dual prossesors. its restart the sysytem or got stuck. for now as far as i know only pc based intel will do it perfect.
    goodluck
