Activity Forums Apple Final Cut Pro Legacy Help! Replace / Overwrite Question
  • Help! Replace / Overwrite Question
    Posted by Dave Tavernier on August 23, 2006 at 4:58 pm
    I have a sequence with a photoshop logo on top of a moving background. My question is: How do I replace the logo layer in the sequence [with another photoshop logo] while maintaining it’s position in the timeline, it’s duration and it’s transitions? Anyone know a time saving trick?
    TIA!
    Dave Tavernier replied 20 years ago 4 Members · 6 Replies
  • David Roth weiss
    August 23, 2006 at 5:05 pm
    Use recconect media and reconnect the cliup on the timeline to the new file.
  • Jeremy Garchow
    August 23, 2006 at 5:20 pm
    Use the replace feature. Load the new logo into the viewer, set your timeline marker to where you want it to start (not the beginning of the logo), go to the timeline, select the track with your logo in it, put the timeline marker in the middle of the logo or so and hit f11.
    Jeremy
  • Dave Tavernier
    August 23, 2006 at 5:42 pm
    I tried that but got an error message: file does not have enough video tracks to reconnect to file in seq.
  • Dave Tavernier
  • Debe
    August 23, 2006 at 6:02 pm
    Another option is to copy the new logo in the Browser using CMD-c. Right click (or CTRL+click if you are of the one-button mouse persuasion) on the clip you want replaced in the timeline and choose “Paste Attributes”. Then tick the box for “Content”, and it should swap the files, leaving all filters and motion tab settings intact.
    debe
  • Dave Tavernier
    August 23, 2006 at 7:10 pm
    Thanks debe,
    that seems to work as long as the files have the same number of layers…….FCP needs to work on this……..
