Activity Forums VEGAS Pro HELP – render issue vegas 9
  • HELP – render issue vegas 9
    Posted by Martin Phillips on July 16, 2009 at 8:21 pm
    Hi All,
    Urgent help needed…..
    I have just finished an edit with vegas 9. The footage is HDV 1080i shot with a Z1, it is edited in HDV and i am rendering out to DVD mpeg2. The footage looks fine when i view it in vegas 9 in the preview window, but when i render it out, the edges of people (particually when movong) is very jagged (you can see this in the render preview window too). I ahve then taken the footage to DVDA, to double check and the jagged edges are there too. I thought this was a feild order issue, and after checking the footage is upper field first as is the render template….. Really need help with this one quickly if poss.
    Thannks
    Martin
    Martin Phillips replied 17 years, 1 month ago 1 Member · 1 Reply
  • Martin Phillips
    July 16, 2009 at 9:29 pm
    Sorted……. i dont know how, but i had changed the deinterlace method setting in the project preferences to ‘none’, when it should be ‘blend’
    at least i can crack on…… have a good one. M
