Activity Forums Adobe Audition Help removing vocals??
  • Help removing vocals??
    Posted by Q1 on July 21, 2005 at 4:44 pm
    I’ve searched the posts and have not really found what I’m looking for.
    I have a good audio track with a good beat but there are a few small section with some vocals that just don’t fit for what I want. I need to figure out how to reomve these vocals.
    Q1 replied 21 years, 1 month ago 3 Members · 3 Replies
  • Willie Toth
    July 21, 2005 at 6:19 pm
    Ron,
    Audition does have a filter for voice removal, however I haven’t really tried it and don’t know how effective it is … I am at work and don’t have the program in front of me and am brain farting on it’s location … Go to the effects tab and look for it in noise removal … If you can’t find it look in the help file ………. WILLIE
  • Ozpeter
    July 22, 2005 at 1:35 am
    You want the Centre Channel Extractor in the Filters menu (introduced in Audition 1.5) which will either remove vocals quite effectively from the centre while leaving the stereo image intact – which is the big advance from the “traditional” methods – or it will leave the vocal and remove everything else, which is a totally new trick. It’s not perfect however – results depend on material, and some phasiness can result – but it’s probably ahead of any other solution unless you spend a fortune.
  • Q1
    July 22, 2005 at 7:08 pm
    Sounds like this will work. There isn’t really much vocals in the song and I’d be happy with just greatly reduced levels of the vocals that are there.
