Activity Forums Adobe After Effects HELP: REALY NEED TO KNOW: First time working with DPX? Why should I use the CINEON CONVERTER and how?
  • HELP: REALY NEED TO KNOW: First time working with DPX? Why should I use the CINEON CONVERTER and how?
    Posted by Noizzz on December 20, 2006 at 8:27 pm
    I going to work with dpx sequences for the first time. But along with the footage I got a readme that said I had to use the CINEON CONVERTER, and that
    Peter O’connell replied 19 years, 8 months ago 3 Members · 2 Replies
  • Chris Smith
    December 20, 2006 at 9:31 pm
    Never used it personally but they are log color space, yes? And needs to be converted to linear color space. Just guessing.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Peter O’connell
    December 21, 2006 at 4:55 pm
    HI the cineon converter allows you to view an approximation of what the DPX files will look like when viewed on the big screen. DPX files contain 1024 levels of gray per channel where black is 95 and white is 685. Everything above 685 clips at white unless you are working in 32 bit.
    Are you delivering cineons?
    Pete
    Sunday; December 17, 2006
    4:01 PM
    barxseven.com
