Activity Forums Apple Final Cut Pro Legacy Help! – Raid won’t mount
  • Help! – Raid won’t mount
    Posted by Shawn Wyatt on September 26, 2005 at 6:50 am
    I somehow lost the desktop icon of my video raid for FCPro.
    I’m running Panther – I can see it in disk utility, and the mount button is activated but when I push it nothing happens.
    Please help if you can – I’m new to Macs and I’m stumped.
    Shawn
    Shawn Wyatt replied 20 years, 11 months ago 5 Members · 10 Replies
  • 10 Replies
  • Torrey Loomis
    September 26, 2005 at 7:47 am
    Shawn,
    Try shutting down both the RAID and the Mac.
    Fire up the RAID, then fire up the Mac. See what happens.
    BTW–what kind of RAID is it?
    Torrey Loomis
    President – Silverado Systems
    Apple Pro Video VAR
    Apple Xsan for Pro Video Certified
    1108 Sandwick Way
    Folsom, CA 95630
    (916) 806-7189
    tloomis@silverado.cc
    https://www.Silverado.cc
    We have Panasonic DVCPRO HD and Sony HDCAM
    Check out our rates at https://www.silverado.cc/rentals.html
  • Shawn Wyatt
    September 26, 2005 at 2:03 pm
    Thanks Torrey,
    I’ve tried that several times – I can see it under disk utilities but it won’t remount.
    It is 4 seagate drives in 2 Seritek enclosures.
    Any help is greatly appreciated.
  • Rennie Klymyk
    September 26, 2005 at 5:28 pm
    I’m just about to purchase this same set-up, now I’m scared! At $469.00 plus the drives it seems like a great storage option. Any one know of other solutions in this price point? Any comments on the Firmtek?
  • Shawn Wyatt
    September 26, 2005 at 5:41 pm
    been great till now
    I was capturing footage last night and it locked up – now the raid won’t mount
  • Torrey Loomis
    September 26, 2005 at 6:13 pm
    Shawn,
    Please forward some information on your setup:
    1. OS Version
    2. Kind of SATA card
    Torrey Loomis
    Apple Pro Video VAR
    1108 Sandwick Way
    Folsom, CA 95630
    (916) 806-7189
  • Shawn Wyatt
    September 26, 2005 at 6:38 pm
    dual powermac g5 2.5 running OS X 10.3.9
    and a Seri-Tek 1VE4
    Thanks – I’m about at wits end
  • Torrey Loomis
    September 26, 2005 at 7:13 pm
    Shawn,
    I have clients who have been very happy with that card, but…
    I would get off 10.3.9 immediately. Upgrade to 10.4 and see if it resolves. There have been a lot of reported problems with 10.3.9.
    Example–Blackmagic will not support any of their cards running on a 10.3.9 based system.
    Torrey Loomis
    Apple Pro Video VAR
    1108 Sandwick Way
    Folsom, CA 95630
    (916) 806-7189
  • John Foley
    September 27, 2005 at 4:13 am
    I am terribly sorry to hear about this but to all of those who are considering this setup – it is a RAID 0 and RAID 0 gives NO security if one of the drives in the set fails in any way. Just the same for a Firewire RAID (if it is a software RAID setup)
    The two or four stripe (disk) is a fast and inexpensive way to get around purchasing a very expensive RAID 3 or 5, but it is capable of robbing you of any and all of the data on those disks.
    I would never recommend that you store ANYTHING on a software RAID that you can not retrieve from tape or other similar backup.
    It has been my good fortune that my four stripe 1.0 TB of RAID 0 has never let me down, but it can and will, if you let it.
  • Mutant0
    September 28, 2005 at 7:10 am
    I had the same thing happen to me. I looked everywhere to find a RAID repair utility. Either it came with your RAID card or you used SoftRAID which has some options. Otherwise, I could find no utility that repairs RAID arrays. Looking at the low level of the drive mounting, I could see that one of my drive pairs was just set as something else — the data could have been fine. I still think it was a simple drive identifier that got set wrong. But since one drive was still “RAID” and the other wasn’t, the pair wouldn’t mount. Using “Data Rescue X” I was able to get some of the files recovered, even though it isn’t designed for RAID (it had to be looking at one drive at a time). Diskwarrior and other utilties did nothing.
    There could be something to repair the drive settings out there … but I haven’t found it. I had to reformat the drives. They work fine now. But when I do a RAID again, I’ll probably use SoftRAID, or find a device that features some repair options. I believe the RocketRaid sports a repair tool.
    good luck.
    Mark J
  • Shawn Wyatt
    October 12, 2005 at 4:53 am
    Thanks Guys for your input.
    I wrestled with Apple’s and Seritek’s people with this for about a day and a half.
    Then a good guy at Apple mentioned DiscWarrior. $90 bucks and the problem was solved in about 30 minutes with only a few clips lost.
    what a relief!
    Shawn
