Activity Forums Boris FX Particle Illusion HELP!! QUES ABOUT COM SPEC!!
  • HELP!! QUES ABOUT COM SPEC!!
    Posted by Eopac_team on April 10, 2007 at 4:02 pm
    I’m using PI3. The problem is the preview while process and after the rendering process, the avi file not run smooth. What must I do? Upgrade the RAM? Or Upgrade the graphic card? What is the best spec? Huwaaa….. 🙁
    Elvis Deane replied 19 years, 5 months ago 3 Members · 2 Replies
  • Ryndemers
    April 10, 2007 at 9:13 pm
    how much ram do you have
    and is you video card external and what kind?
  • Elvis Deane
    April 11, 2007 at 1:25 am
    What compression codec are you using when you save the AVI? By default, you’re probably saving out to uncompressed, which is around a meg a frame for a 640×480 image size. XVID and DIVX are good ones to save out to for viewing purposes.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
