Activity › Forums › Live Events & Streaming › HELP – QT stuttering on interlaced video playback.
  • HELP – QT stuttering on interlaced video playback.
    Posted by Andy Stokes on March 20, 2008 at 4:15 am
    Hi all,
    I’m having problems with Quicktime playback of Interlaced video.
    For testing purposes, I’m playing back a PAL 20 second h.264 clip on a secondary display attached to my MacBookPro with the Apple DVI-S-Video adaptor (set to 720×576 PAL).
    When I play the clip, it stutters/flickers (almost like the fields are inverted).. If I pause then play the movie repeatedly the problem seems to rectify itself for a few minutes, then it happens again, until I pause/play again.
    I have tried different codecs and different players, but all with the same problem. It even happens when I “present movie” in quicktime. Has anyone experienced this problem? (and hopefully found a fix). I need to solve this ASAP since the clips need to loop for an unattended tradeshow setup.
    Any help would be appreciated.
    Cheers,
    Andy Stokes replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
