Activity Forums Adobe Premiere Pro HELP! Premiere Pro Window Layout Frustration!
  • HELP! Premiere Pro Window Layout Frustration!
    Posted by Sleddriver1 on January 24, 2007 at 4:28 pm
    This is just weird, but tremendously frustrating. I’m on a fresh install of Premiere Pro 7 within a fresh install of WinXP after a motherboard crash/replacement, and PP7 isn’t behaving the way my “old” install of PP7 did. Previously, opening a project that was laid out for dual monitors restored the window layout exactly as I had left it last time I saved it…stretched across both monitors, and every window in its preferred place. Now, opening the same or similar project only opens PP7 in one monitor, with everything crunched up. I can stretch the PP7 window out to 2 monitors, and go through the Window Workspace menu to restore my preferred window layout, but why should I have to? It’s the same ol’ software and everything, just a new motherboard. No matter what I do, I can’t seem to get it to open up with a full dual-monitor layout from the get-go. GAAAAAHHHHH!
    Solutions welcome!
    Sleddriver1 replied 19 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Robert Hallion
    January 24, 2007 at 9:08 pm
    Sounds like a video card setup issue. Check your settings, is your display mode set to Dualview? If it isn’t that might be why it isn’t working.
  • Sleddriver1
    January 24, 2007 at 10:39 pm
    Yep, sure is. For instance, when I bring up AE 6.5 or CoolEdit Pro, they automatically launch into the layout I’ve set for them, which spans both monitors. It’s only a Premiere problem, that’s the weird thing.
  • Harm Millaard
    January 24, 2007 at 11:11 pm
    Save your project with the lay out you want, exit PP, refresh your preferences and try again.
  • Aanarav Sareen
    January 25, 2007 at 2:27 am
    Try this:
    a) Open project
    b) Change workspace
    c) Save workspace
    d) Edit your project a little bit (move the files on a sequence or create a dummy sequence)
    e) Save your project
    f) Open your project again.
    Does that help?
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Sleddriver1
    January 25, 2007 at 1:26 pm
    No, it doesn’t help, and this is my frustration. I do have one thing I want to try when I get home tonight, so I’ll post again later.
    Thanks for the advice.
  • Sleddriver1
    January 25, 2007 at 1:27 pm
    This may work; I’ll try it tonight when I get home.
  • Sleddriver1
    January 26, 2007 at 12:56 pm
    Bummer! My idea didn’t work. Any other ideas out there?
