Activity Forums Adobe Premiere Pro Help Prem CS4 Audio Features (Mute-Pan-Split)
  • Help Prem CS4 Audio Features (Mute-Pan-Split)
    Posted by Diego Pocovi on May 29, 2009 at 5:30 pm
    Hi there is a way to an audio clip or audio of a video track change Pan or Mute L or R, or even split both tracks, all on the same clip on the secuence (not in the track audio features) without replacing the audio for a new one?.
    Other thing: When capturing true the Black Magic video and stereo audio, the premiere see my clip as 2 mono tracks why?..
    Thanks, please help…
    Diego
    Jason May replied 17 years, 3 months ago 3 Members · 2 Replies
  • Eddie Lotter
    May 29, 2009 at 6:14 pm
    [Diego Pocovi] “Pan or Mute L or R”
    Yes. Details are in the PPro Help.
    [Diego Pocovi] “split both tracks, […] without replacing the audio for a new one?.”
    No.
    Cheers
    Eddie
  • Jason May
    June 24, 2009 at 12:00 am
    I’ve had the same problem when importing from OL. I can’t find the cause (help anyone), but I found a quick fix. If you’re in CS4, click on the clip in the projects window, then in the menu bar choose clip, audio options, and source channel mappings. This will allow you to change a ‘2 mono’ track to a single stereo track.
    Hope that helps.
    jasonhonduras.com
