Activity Forums Apple Final Cut Pro Legacy Help, pls! Lost Real-Time Functionality?!?!?!
  • Help, pls! Lost Real-Time Functionality?!?!?!
    Posted by Max Frank on March 29, 2008 at 11:44 pm
    For some reason I’ve lost all my real-time functionality.
    My RT settings are:
    Safe RT
    Playback Video Quality & Frame Rate: Dynamic
    Record To Tape: Full Quality
    I’m not sure what’s going on, because it was working perfectly a little earlier.
    I’m working on a DV NTSC timeline on a MBP, FCP 6.0.2
    I’ve also trashed my prefs.
    Any suggestions?
    Wayne
    Max Frank replied 18 years, 5 months ago 4 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    March 30, 2008 at 12:11 am
    What do you mean you lost it? What is happening?
  • Max Frank
    March 30, 2008 at 12:18 am
    Hi Jeremy,
    Thanks for replying.
    For instance, I have a red render bar over text that normally plays real-time.
    Any ideas?
    Wayne
  • Jeremy Garchow
    March 30, 2008 at 12:23 am
    Yes, thanks for asking and answering.
    This usually means that you need to render your timeline as your RAM quota has been reached.
    GO up to your Sequence > render all and sequence > Render selection menus and make sure to check all of the options, especially the one marked ‘full’. Then render your timeline. The next time you drop on a text effect, you should see a green rt bar.
    Jeremy
  • Max Frank
    March 30, 2008 at 12:56 am
    Hi Jeremy,
    Thanks for the time.
    That’s not helping.
    Any other suggestions?
    Wayne
    PS – when I try a new project, the titles work perfectly in real-time. I’ve also rebooted.
  • Jeremy Garchow
    March 30, 2008 at 1:03 am
    What are you putting the title over?
    Try turning your rt to unlimited.
    Are you absolutely sure that all of your rt effects are rendered?
  • Max Frank
    March 30, 2008 at 1:10 am
    The titles are red whether over a video clip or none at all.
    Even Boris Title 3D is rendering red.
    Renders orange on unlimited RT.
    Wierd stuff, because everything was working perfectly a little earlier!!?!?!
    Thanks again,
    Wayne
  • Jeremy Garchow
    March 30, 2008 at 1:17 am
    And you are ABSOULTELY sure everything is rendered. You have a solid blue line over your whole timeline?
  • Max Frank
    March 30, 2008 at 1:39 am
    Yeah, everything is blue.
    There must be something corrupting the time-line.
    I have to call it a day right now, but thanks so much for your effort Jeremy.
    Tomorrow I’ll have to go through the TL and see what could be causing the problems.
    Thanks again,
    Wayne
  • Rafael Amador
    March 30, 2008 at 2:25 am
    Hi Waine,
    Unplug everything and trash the preferences again (FC Pro 6.0 Prefs, Pro Obj cache, Pro Prof Cache +com. apple. FinalCutPro.plist).
    Let FC make a new “Profiling for RT”.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Kevin Monahan
    March 30, 2008 at 8:39 pm
    Make sure you are in Unlimited and not Safe RT. That’s the main one.
    Kevin Monahan
    fcpworld.com
    Author – Motion Grahpics and Effects in Final Cut Pro
