Activity Forums Maxon Cinema 4D Help please! texture affecting model
  • Help please! texture affecting model
    Posted by Megan McCarron on October 16, 2021 at 11:56 pm
    So I have modelled a bird in cinema. I have also created a fluid like animation using mr. mercury in AE and have brought this into cinema as a texture. When I place this onto my model, as a png with the alpha, the tail is affected differently to the rest. It is either not visible at all or briefly flicks into a pattern, like the image below. I have attempted to try changing the comp in AE but no change. How do I get the tail to produce the same effect with the texture as the rest?
    I hope this makes sense. Thanks!
    Andy Kiernan replied 4 years, 10 months ago 2 Members · 1 Reply
  • Andy Kiernan
    October 20, 2021 at 9:43 am
    has the model been UV’d at all? if not the texture projection will be hit and miss. you could try a cubic projection.
