Activity Forums VEGAS Pro HELP! Playback motion not smooth
  • HELP! Playback motion not smooth
    Posted by Mechelle Stewart on June 29, 2008 at 7:52 pm
    I’m still kind of new with Vegas 8 movie studio. Window’s Movie Maker was a cakewalk. Here’s what I’m doing. I’m making a “part two” to a Harry Potter music video that I made with WMM. So I’m using several clips from the movies. However, when I play it back, the motion isn’t smooth. The video will occasionally hang in places as the audio continues as it should. I thought maybe it was from zooming in and out so much to apply my clips and FX affects so I tried saving it, then reopening it again. Still does the same thing, and not always on the same clips.
    Is there another setting I should be applying for smooth motion, instead of it looking choppy? Do I have to apply such a feature to each clip, or can I apply it to the whole track?
    Mechelle Stewart replied 18 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Rasnic
    July 3, 2008 at 9:01 pm
    The chopiness is directly related to how fast your processor is and what fx or pan/crop edits you are doing/applying (and what the file type is of the video). The chopiness will only be there when you preview it. It will not show up on your final output file.
    I don’t know if the consumer versions of Vegas have ram preview, but if it does, depending on the amount of ram you have, you can see a realistic preview for a selection on the timeline that is tied to the amount of ram you have- look for RAM preview in the help file for your version of Vegas.
    j razz
  • Mechelle Stewart
    July 12, 2008 at 2:02 am
    Thank you muchly! I was hoping that was the case, and you’re right. I played the files after rendering them, and they ran smoothly!
