Activity › Forums › Apple Final Cut Pro Legacy › HELP! Photo JPEG Flicker – Jaggies – Banding
  • HELP! Photo JPEG Flicker – Jaggies – Banding
    Posted by Matt Steeves on December 4, 2007 at 10:10 pm
    There is a nasty flicker/banding in two Getty images shots that I purchased. One is a pan and one is static. I have been doing some searching on the COW and found some answers in pulldown, etc. Flicker filter does not work, and de-interlacing does nothing to help.
    I even opened the clip in after effects and tried a number of things. I have noticed this problem with DVCPRO50 footage as well, it seems more frequent with hi-res SD footage.
    This is somewhat urgent…What can I do??
    Jeremy Garchow replied 18 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    December 4, 2007 at 11:40 pm
    What timeline are you working and what size is the footage?
  • Matt Steeves
    December 5, 2007 at 2:07 pm
    It shows up in a standard 8bit NTSC timeline and in my DVCPROHD 720p timeline….as well as quicktime player and After Effects.
  • Jeremy Garchow
    December 5, 2007 at 7:52 pm
    So it seems that the compression is a little much on your footage.
    Can you call and get a less compressed version?
