Activity › Forums › VEGAS Pro › HELP! Pan/Crop doesn’t go to edge…
  • HELP! Pan/Crop doesn’t go to edge…
    Posted by Barbaric Eric on February 23, 2007 at 7:58 pm
    Hey all,
    Well, I jumped in, got Vegas, and now a problem.
    When using Pan/Crop and Keyframes, my pics slide in starting about a quarter the way in from the left, and disappear about a quarter of the way in on the right.
    Hope that makes sense.
    I need to know if there’s a way to make them slide in from the very edge of the screen and go away to the very edge?
    Thanks for any help!
    Eric
    Dave Petteruto replied 19 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    February 23, 2007 at 10:23 pm
    In pan/crop, right-click the image and choose “Match Output Aspect”
    Edward Troxel
    JETDV Scripts
  • Barbaric Eric
    February 24, 2007 at 4:59 am
    Thanks for the help, but in Vegas 7 there’s no such command.
    There’s one about Aspect Ration, which fixes the problem, but it also causes my pictures to change their size, forcing me to manually resize them.
    Any other ideas? Thanks!
    Eric
  • Edward Troxel
    February 24, 2007 at 2:13 pm
    [Barbaric Eric] “Thanks for the help, but in Vegas 7 there’s no such command”
    Yes there is. I use it all the time! (Actually I usually do it via a script but the manual command IS still there).
    Add the picture to the timeline, open the Pan/Crop dialog, right-click the image in the Pan/Crop dialog, and choose “Match Output Aspect”. You’ll have to zoom back out on the image but the edges will expand or contract as you change the zoom level now.
    Edward Troxel
    JETDV Scripts
  • Barbaric Eric
    February 24, 2007 at 4:05 pm
    Ouch! Yep, I see it now, I was looking at all of the options on the left and didn’t think about right-clicking.
    Along that same line, though, is there a setting somewhere to make this the default?
    Or do I just need to make sure all my pictures conform to my projects Aspect Ratio? (ie… 720×480 movie, so all pics have this ratio)?
    Thanks for the help!
    Eric
  • Edward Troxel
    February 25, 2007 at 12:17 am
    I just add all the images to the timeline, select them all, and then run a script that will fix them all at once.
    Edward Troxel
    JETDV Scripts
  • Dave Petteruto
    March 6, 2007 at 2:34 pm
    “I just add all the images to the timeline, select them all, and then run a script that will fix them all at once.”
    Where can one find this script?
    Dave P.
  • Edward Troxel
    March 6, 2007 at 2:41 pm
    I use Excalibur but there’s a free one that does the same thing here:
    https://www.ayizwe.net/VegasScripts/
    Edward Troxel
    JETDV Scripts
  • Dave Petteruto
    March 6, 2007 at 3:53 pm
    “I use Excalibur but there’s a free one that does the same thing here:
    ” target=”_blank”>https://www.ayizwe.net/VegasScripts/”
    Thanks Edward, I appreciate it.
    Dave P.
