Activity › Forums › Apple OS X › HELP! One of my Hard drives went “read only” on me!
  • HELP! One of my Hard drives went “read only” on me!
    Posted by Anthony Popolo on July 28, 2009 at 6:33 am
    I just upgraded to os 10.5, and when I was done, one of my hard drives (not the startup drive) became “read only”. I can access all the files on it, but I can’t resave any of them or any new files to that drive!
    I did a “get info” on the drive and the permissions are all greyed out with the words “Read only”.
    How can I change it to “read and write”???
    Thanks.
    Anthony
    Craig Alan replied 17 years, 2 months ago 3 Members · 4 Replies
  • Chuck Reti
    July 28, 2009 at 11:32 am
    Do “Get Info” (CMD-I) on the drive, see if “Ignore permissionas on this drive” is checked.
  • Anthony Popolo
    July 28, 2009 at 4:13 pm
    At the bottom of the “get info” panel, the “Ignore ownership on this volume” is NOT checked. However, it is also grey-ed out so I can’t access that checkbox.
    Also, just above that shows a list of names / privileges as follows…
    “System”/ read and write
    “admin” / read and write
    “everyone” / read only
    I’m assuming I fall under “everyone” (since I’m ” read-only”)even though I’m the only user (and admin).
    How do I change that privilege?
    Anthony
  • Anthony Popolo
    July 28, 2009 at 6:54 pm
    Hi Chuck,
    thanks for your input.
    I still have an OS on the other drive (so I can run a couple of classic programs I still use). I had to startup on that drive (as the admin) and changed the permission for “everyone” to read and write. So when I came back to the new OS, I was able to read AND write ot it.
    Thanks for getting me thinking!
    Anthony
  • Craig Alan
    July 28, 2009 at 8:29 pm
    Glad you found a work around. Be sure to repair permissions after any update or when these issues pop up. Since you were/are the admin that should not have been an issue. But I have found that non-system drive permissions can be problematic with OS X, though each update has improved on this.
    OSX 10.5.7; MAC Book PRO (EARLY 2008); Camcorders: Sony Z7U, Canon HV30, Sony vx2000/PD170, Canon xl2; Pana, Sony, and Canon consumer cams; FCP certified; write professionally for a variety of media; teach video production in L.A.
