Activity › Forums › Canon Cameras › Help on wiring an Anton Bauer to a 4 pin XLR
Posted by John March on July 28, 2007 at 1:57 amI AM WIRING AN ANTON BAUER BATTERY PLATE TO A FOUR PIN XLR. I AM NOT SURE OF THE POLARITY ON THE PLATE, AND CANNOT FIND ANY DIAGRAMS OR PIN WIRING. HELP PLEASE
Todd Terry replied 19 years, 2 months ago 2 Members · 1 Reply -
1 Reply
Todd Terry
July 30, 2007 at 10:33 pmOk John…
First of all it is VERY important that you do this exactly right… if not (cross polarity), it can have very bad consequences.
Ok step one… the goldmount plate. Hold the plate so that you are looking at it with the two connector pins facing UP (and the three mounting holes in the place will make a “face,” two holes at top for eyes, and one hole at bottom for mouth). If you are holding it like that, then the pin on the LEFT is NEGATIVE, and the pin on the RIGHT is POSITIVE.
The way that it is oriented on the picture below, the LOWER pin is NEGATIVE and the UPPER pin is positive…
You want to wire the AB plate so that the NEGATIVE of the goldmount connects to pin number ONE on your four-pin XLR connector (well, I said pin, but it’s a hole, not a pin, you should be connecting to a female XLR connector). And connect the POSITIVE of the goldmount to pin number FOUR on the XLR. The other two pins on the XLR aren’t connected to anything.
GOLDMOUNT with pins pointing up
LEFT is NEGATIVE
RIGHT is POSITIVEXLR connection from goldmount
PIN 1 connects to goldmount NEGATIVE
PIN 2 is unconnected
PIN 3 is unconnected
PIN 4 connects to goldmount POSITIVESorry for the repetition, just wanted to stress how important it is that this is not hooked up backwards.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
