Activity Forums Adobe After Effects help on rendering
  • help on rendering
    Posted by Mjportal on August 9, 2006 at 10:49 am
    dear all
    i have just finished a creative cow tutorial (creating a nebula) and i am trying to render it. however the render avi file is very heavy (hundreds of mb)
    i noticed that the final movie downloadable from the tutorial is only 6mb and it has indeded a very good quality.
    how can i achieve the same results also for my files?
    thx in advance
    Mjportal replied 20 years, 1 month ago 2 Members · 2 Replies
  • Michael Duff
    August 10, 2006 at 3:17 am
    HI –
    most likely you are rendering AVI uncompressed….resulting in a huge file (but top quality).
    you need to use a codec to compress the file (https://en.wikipedia.org/wiki/Codec)
    you set the codec in the Output section of the render queue….
    depending on what you want to do with the file afterwards will determine which codec/file type to use.
    may I suggest trying a quicktime file with Sorenson Video 3 compression if you are just rendering for viewing on your PC/CD-ROM or Web. Try playing around with different settings and you will learn what they all do.
    -hope this helps
  • Mjportal
    August 10, 2006 at 11:33 am
    thank you for your precious help.
    it really helped me .
    take care
    nick
