Activity Forums Adobe After Effects Help on Rendering…
  • Help on Rendering…
    Posted by Css008 on August 24, 2007 at 7:47 pm
    I have looked in the FAQ and still am not sure as to what to do?
    I’ve designed a slideshow for a wedding using AE and it’s approx. 5 min. in length. Usually I design for DVD at 720×480, render an uncompressed avi, and then encode after.
    I was told to construct the slideshow at 1024×768 (4:3) because it is the aspect ratio projectors use. I would like to know how I can render my project to get a manageable file size while still retaining a high quality video? (Any codecs recommended?)
    Jason
    Css008 replied 19 years, 1 month ago 2 Members · 2 Replies
  • Todd Gillespie
    August 24, 2007 at 8:15 pm
    You’re getting a little misinformation for what you’re trying to do.
    Yes 1024×768 would be a good resolution for playing a file for a video projector via a laptop, but NOT for DVDs. If you made a DVD from the 1024×768 video file, Encore (or any DVD authoring prg) will compress that down to 720×480.
    You basicaly have 2 choices:
    Render a movie to use to make a DVD
    Or render a movie (1024×768) to be played on a laptop to projector. But you will need to do some testing to see which codec at which data rate will give you a good video. A 1024×768 movie file may not play on a lot of laptops, so you may need to compress the video so much so that it looks worst than just playing a DVD. -Again, it will depend on your laptop, codec, etc.
    Good Luck,
    Todd at UCSB
    Television Production
  • Css008
    August 24, 2007 at 11:04 pm
    I’m not trying to make a DVD. I need to render a movie (1024×768) to be played on a laptop to projector. Any suggestions on codecs to achieve a small file size and high quality video at the same time?
