Activity Forums Adobe After Effects Help On Lens Flare Effect On White Background
  • Help On Lens Flare Effect On White Background
    Posted by Bryan on April 12, 2005 at 8:28 pm
    I have a line animating and drawing an image with paths from Illustrator. The line is black and the BG is white.
    Does anyone know how I would make the leading part of the animation have a bright blue, star like (lens flare) effect?
    I tried the effect with a white line and a black BG and it worked fine. I also tried all the different layer modes.
    It is possible, even with something else (another plugin perhaps) that would achive this effect on a white BG?
    Bryan
    Matt replied 21 years, 5 months ago 3 Members · 3 Replies
  • X-claim
    April 12, 2005 at 9:06 pm
    Does it still work when you invert the black background version that you did?
    Channel>Invert
    Hayden
    New Zealand
  • Bryan
    April 12, 2005 at 9:16 pm
    Thanks, that did the trick, did not even think about that one.
    It does kind of loose it’s effect, but using some color balance brings it back some.
  • Matt
    April 13, 2005 at 12:14 am
    You can apply the “unmult” effect to the lens flare layer as well. It’s a free effects from Knoll.
