Help! Old ppj into Prem Pro 2 problem
Hello,
Can you people can help me please.
I want to re edit an older Prem6 ppj in Prem Pro2. Problem is when I open it, after it’s converted, just after the project loads I am faced with the message ‘the editing mode used by this project could not be loaded. The project will be opened in Desktop Mode’! I am stuck in that mode and can’t change it to the Matrox mode and output via RT.X 100 like I did when I created it in Prem 6, what’s with that?Tried starting with a new project and importing the ppj instead, but when I drag it from the bin onto the timeline it is not laid out the same way on the timeline (accross 5 video & 3 Audio tracks) instead it’s merged together on Vid 1 and Audio 1?
Any help would be appreciated.. Thank you.
