Activity › Forums › Apple Final Cut Pro Legacy › Help nightmare situation
Posted by Jb on April 16, 2005 at 10:31 pmWe where editing using fcp-5 on a dual 2.2 g5 using and extrenal 250gb seagate ide disk. The disk fell off the desk and diagnosed as dead. 2 questions (we are not regular fcp users)
1- whats the least expensive data recovery available?
2- would fcp-5 rebuild the projects if i just feed the media on a new disk?
your prompt help is urgently needed pleeeeeeeeeeeeeeassssssssssssssssssssssss…etc etc
jb
save a life
Thaxter Clavemarlton replied 21 years, 5 months ago 5 Members · 10 Replies -
Walter Biscardi
April 16, 2005 at 11:12 pm[james bannfield] “2- would fcp-5 rebuild the projects if i just feed the media on a new disk? “
If you have the media on another drive, then you can reconnect the media to the project using Reconnect Media. If you don’t have the media at all, then just recapture the project using the original tapes.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Jb
April 17, 2005 at 12:19 amso reconnect media can be used after i recapture on a new disk? is this true with dv media?
thanks for you prompt response
jb
Guy
April 17, 2005 at 12:27 amJust click on all the footage that is now offline and do a batch capture. If you set reel names for the tapes during original capture this should be no problem, just feed it the tapes it tells you.
Walter Biscardi
April 17, 2005 at 12:34 am[guy] “Just click on all the footage that is now offline and do a batch capture. If you set reel names for the tapes during original capture this should be no problem, just feed it the tapes it tells you.”
Exactly. Just do as Guy says and once you complete the batch captures, your Sequence will be put right back together.
Jb
April 17, 2005 at 12:43 amWow if this works i am saved and the life of my associate would be spared (lol)
i’ll buy a new ext drive and test it
thanks a lot guys
jb
Walter Biscardi
April 17, 2005 at 12:45 am[james bannfield] “i’ll buy a new ext drive and test it “
Just spread a bunch of pillows around the floor beneath the drive. That should save the next one if it happens again. 🙂
Jason Levy
April 17, 2005 at 1:39 amIt was only up to 4.5 last I heard.. Is there anything you want to tell us? 😉
jason
Jb
April 17, 2005 at 2:00 amsorry we are not very familiar with the lates version of fcp the last ones we used where version 2. we are basically guys from the other side of the wall working by chance on fcp.
jb
Jb
April 17, 2005 at 2:01 amsorry we are not very familiar with the lates version of fcp the last ones we used where version 2. we are basically guys from the other side of the wall working by chance on fcp again.
jb
April 17, 2005 at 4:58 pm[Walter Biscardi] “Just spread a bunch of pillows around the floor beneath the drive.”
A tube of “Crazy Glue” is cheaper.
Just make sure your associate is sitting in a comfortable position before you stick him down.
