Activity Forums Adobe After Effects Help needed with CS4 Aspect Ratios
  • Help needed with CS4 Aspect Ratios
    Posted by Karim Daire on August 24, 2009 at 8:15 pm
    I am wondering about the new aspect ratios in AE CS4.
    Up to CS3 I have always been working in PAL with 768×576 and 1024×576 square pixels and then placed my comps in PAL or PAL Anamorph Comps for output to Final Cut or Avid.
    Since CS4 the ratios changed and I need other widths. Of course in AE working the the new square pix and PAL Ratios fits fine But why is that only in Adobe Software? I mean, everything is compatible with Final Cut or Avid if I output a square pixels Clip with Animation Codec with the old settings and render in FCP. With the new widths it doesn’f fit in my editing software, so why did Adobe change the ratios and why did they do it excactly now with CS4??
    Thanks for any hints in advance,
    Karim
    -Karim-
    Todd Kopriva replied 17 years, 1 month ago 2 Members · 1 Reply
  • Todd Kopriva
    August 25, 2009 at 1:58 am
    Some major broadcasters and some software companies asked us repeatedly to fix the pixel aspect ratios for some older, standard-definition formats. We did. When the wrong thing has been done for long enough, many people consider it to be “right”, so this change has certainly taken some time and effort to adjust to.
    To learn how to work with the pixel aspect ratios, why they were changed, and even how to avoid using the correct values, see this page and this page.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
