Activity Forums Apple Final Cut Pro Legacy help needed urgentaly!
  • help needed urgentaly!
    Posted by Niti Shah on June 7, 2006 at 7:55 am
    hi everybody
    i am working on a film(24fps). my source is on film (24fps) wich has been transfered to video (telecine 25Fps). audio is on dat.first i captured video and i changed frame rate from 25 to 24 fps(conforming) with the help of cinema tools.afterwards i matched audio and video wich was in sync. then linked audio video(apple L). and tried to make subclip (apple U). bhoom. it made a subclip but not in a sync. what it meda was fisrt only audio in black and then video without audio in the same subclip. i have tried various tricks but nothing helped. guys your help needed urgentaly
    regards
    nikei
    G5 2.3 os 10.4.2, fcp 5.0.4, QT 7.0.1, cinematools 3.0
    Niti Shah replied 20 years, 3 months ago 2 Members · 2 Replies
  • Nick Meyers
    June 7, 2006 at 12:27 pm
    i understand your process,
    but not sure i quite understand what you’re describing as the result.
    however, i *suspect* that your audio might not have reel numbers.
    give your audio clips reel#s,
    and try again.
    hope that helps,
    nick
  • Niti Shah
    June 9, 2006 at 6:12 am
    hi
    thanxs nick. i do have reel number for my audio clips. hat is happening as a result is, when i play subclip its not in a sync it shows first only audio and then only video. totaly dislocated.
    regards
    nikei
