Activity Forums Adobe After Effects help needed for the stroke effect
  • help needed for the stroke effect
    Posted by Deeps_n on August 29, 2006 at 8:25 pm
    I have been trying to get this effect from a long long time, i have been using after effects from the past 5 months. I wanted to animate a stroke (i.e the end parameter) and make the camera follow it in different axiz maybe rotation too.
    Pls help
    Mike Clasby replied 20 years ago 2 Members · 1 Reply
  • Mike Clasby
    August 30, 2006 at 1:44 am
    Maybe this earlier post from Dan will help, also read the before and after via aa advanced search if you have problems, the original poster had pixel aspect problems, here’s the post:
    Date: Jul 18, 2005 at 9:21:05 am
    Subject: Re: how make object follow path
    Here’s one way. Let’s say your layer with the stroked path is called “Stroke Layer”. Copy the mask shape for the path and paste it into the position parameter of your follower layer. This should create keyframes that cause the follower to trace out the path over a 2-second period. Then just add this expression for position to sync it up with the animation of the “End” parameter of the stroke effect:
    percent = thisComp.layer(“Stroke Layer”).effect(“Stroke”)(“End”);
    valueAtTime(2*percent/100)
    Dan
