Activity Forums Apple Final Cut Pro Legacy Help Needed! Exporting .mov to DVD
  • Help Needed! Exporting .mov to DVD
    Posted by Acorn5 on July 15, 2005 at 2:31 am
    Hello!
    i am new here. i am hoping that you will be able to help me with a problem i’ve been having.
    i am trying to export .mov files, and then dragging it to iDVD.
    however, i don’t understand how a 1GB .mov file becomes 3 or 4GB in iDVD and takes up the entire DVD space, such that i don’t have space for any more.
    what i’ve been trying to do is to minimize the filesize without compromising on video quality, but been faced with frustrations.
    what i’ve done so far is to set the size to 640×480 and play around with the data rate and keyframe per second. i also used sorenson 3.
    what is the ideal rate such that i can minimize the size without compromising on image quality?
    please help!
    Acorn5 replied 21 years, 1 month ago 2 Members · 3 Replies
  • Jerry Hofmann
    July 15, 2005 at 3:39 am
    Export a non self contained QuickTime movie from FCP of your sequence(s). Open this file in iDVD, and choose the best MPEG compression it does. THIS is the cleanest way to work. No compression done at all before the big one (the MPEG compression) that iDVD does.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Acorn5
    July 15, 2005 at 5:33 am
    sorry, this may sound a little dumb, but how do i choose the best mpeg compression from iDVD?
  • Acorn5
    July 18, 2005 at 1:35 am
    Hi Jerry,
    I’ve tried what you suggested…however, the same problem still occurs. i even tried exporting the .mov file as mpeg-4, and that greatly reduced the filesize (to about 209 MB), but once i drag and drop it into iDVD, it takes up 2.4GB…i just can’t understand it…
    also, how do i choose the best compression in iDVD? i must be missing something here…can’t seem to find it in iDVD…
    please help!
