Activity Forums Adobe After Effects Help! need to Render only animated text
  • Help! need to Render only animated text
    Posted by Luis Cosme on August 14, 2008 at 12:12 am
    I created all my animated text for a 30 second spot and I want to export it and put it over my video in Final Cut Pro, but when I bring it over, it always has the background. I need no background only the animated text. Please help. My Final cut video files are DVCPRO50. Thanks!
    Luis Cosme replied 18 years, 1 month ago 58,810 Members · 1 Reply
  • Luis Cosme
    August 14, 2008 at 6:24 pm
    Dave,
    Thank you very much.
    By the way when I said “Export” I meant Render.
    Then I should have typed “Render” right? lol…
    Anyway I tried both Animated and PNG with RGB + Alpha and Premultiplied (Matted) and it worked great.
    I will try one more now “Straight” just to see if there is anything different in the render, but it looks like I’m good to go.
    Thanks again!
    -Lou-
