Activity › Forums › Adobe Premiere Pro › Help!!! Need to Export High Quality Flash File
  • Help!!! Need to Export High Quality Flash File
    Posted by Eddie Kantis on January 30, 2008 at 8:33 pm
    Hello everyone,
    Im trying to export a movie as a flash file and I need it to be the best quality picture as possiable. My target audince is people that have a high speed internet connection .. now i know the higher the bit rate the better the picture. what would be the highest recommend bit rate i can set it to.
    Thank you
    Tedy Necula replied 18 years, 3 months ago 3 Members · 6 Replies
  • Jeff Brown
    January 30, 2008 at 9:27 pm
    I’d suggest between 800 and 1200 kilo BITS per second… At the high end, many people will probably have a bit of a delay as it buffers, but not too much.
    -jeff
  • Eddie Kantis
    January 30, 2008 at 10:54 pm
    i had it before at 2000 but it was pausing then when i set it to 1000 or less i got poor quality but when i set the noise reduction option on and set it to 3 and the bits to 500 it made a big diffrence in qualiy, can you please tell me what you would recommend for a good setting for the noise reduction.
    Thanks for the help
  • Eddie Kantis
    January 31, 2008 at 6:47 am
    what would be the best noise reduction setting to use.
    thanks
  • Jeff Brown
    January 31, 2008 at 1:20 pm
    I rarely use Premiere for encoding; when I do, I do not use noise reduction. It takes too long…
    I use Cleaner (Autodesk) for compressing, which seems to do slightly better compression than other systems, although I have not tried the most recent incarnation of Squeeze.
    -jeff
  • Eddie Kantis
    January 31, 2008 at 6:38 pm
    Hello Jeff,
    thanks for responding, i was up all night scrathing my head because i have seen other companies like mine put up demos with really good quality.. anyways i figured out the problem and you are right premiere pro isnt good for exporting flash for the web, what i did was render out the file as a avi and then brought that into encore and encore lets you do flash and the quality came up better then i could of ever hoped for.
    thanks for the help.
    Eddie
  • Tedy Necula
    June 19, 2008 at 9:15 am
    Hi everyone!
    I have a problem. I exported a FLV in Premiere. a 4 hours material (it is a course). I have to put it on the web and on DVD also. The size is very good 1600kb, The quality is best.
    But sometimes in the clip when I run it with windows media player, appears few “scratches”-pink pixels on all the image. Even in the starting of the clip, the “scratch pixels” are there for 1-2 seconds.
    What I can do?
