Activity Forums Apple Final Cut Pro Help! Need to convert an old FCP Project file from 10.0.x to an XML or 10.4.5
  • Help! Need to convert an old FCP Project file from 10.0.x to an XML or 10.4.5
    Posted by Teo Camporeale on September 11, 2020 at 10:33 pm
    Hello, I know this is a long shot: DOES ANYONE OUT THERE HAPPEN TO HAVE A WORKING INSTALL OF FCP 10.0.X OR UP TO 10.3? I need to work with an older Final Cut project file, but I did not know that after FCP 10.3, you cannot access the file even to convert it. My old machine that had 10.0.x installed died, and even if I could find the installers, it probably wont run on the new mac OS… If anyone could help, I’d be happy to pay something for your effort! Thank you!
    Teo Camporeale replied 5 years, 4 months ago 3 Members · 4 Replies
  • Patrick Donegan
    September 18, 2020 at 5:18 am
    I thought i had already replied.
    I have an iMac 2011 dual boot and will see if i can open that file.
    I also have some old cloned systems, so I will be able to run FCPX 10.3/
  • Teo Camporeale
    September 18, 2020 at 12:26 pm
    Hi Patrick, thank you for your reply! I think you did answer on FCP.co ? My apologies for not responding to that sooner– I actually got it converted. And, my memory being not so sharp, and since I didn’t make project notes on this one before archiving, it turns out it was actually a FCP 7 file! Luckily the person who tried it happened to still have 7 available and was able to convert. My lesson is well learned though: ALWAYS make an XML backup of the project before archiving! Thanks again for responding.
  • Karine Baczynski
    October 2, 2020 at 3:31 pm
    Hey Patrick, Sorry to bother you, but I’m in a similar situation. I was able to get some old FCP7 project xmls created and they open in FCPX, but some of the media files relink and some don’t? They are all in DV/DVCPRO codec. Since it sounds like you’ve done this before, I’m wondering if you might know what the problem is? Any words of advice?? Thank you!
  • Teo Camporeale
    May 1, 2021 at 4:02 pm
    Hi Karine, I just logged back into Creative Cow for the first time since… well, when I posted that last October. I hope you found a solution to the issue. For me, my project files were so old, there was no conversion path possible using current software. I literally got lucky with a kind soul on an FCP forum, who happened to have an old mac in an closet, that still had FCP-Pro installed. He took the time to convert my project file to xml and from there I was able to open it in Premier. Everything had to be manually re-linked, but it seemed like the timings and cuts were more or less preserved.
    All the best, Teo
