Activity Forums Apple Final Cut Pro Legacy Help! Need to convert an old FCP Project file from 10.0.x to an XML or 10.4.5
  • Help! Need to convert an old FCP Project file from 10.0.x to an XML or 10.4.5
    Posted by Teo Camporeale on September 11, 2020 at 10:36 pm
    Hello, I know this is a long shot: DOES ANYONE OUT THERE HAPPEN TO HAVE A WORKING INSTALL OF FCP 10.0.X OR UP TO 10.3? I need to work with an older Final Cut project file, but I did not know that after 10.3, you cannot access the file even to convert it. My old machine that had 10.0.x installed died, and even if I could find the installers, it probably wont run the new mac OS… If anyone could help, I’d be happy to pay something for your effort! Thank you!
    Teo Camporeale replied 5 years, 9 months ago 2 Members · 2 Replies
  • Patrick Donegan
    September 11, 2020 at 11:25 pm
    I think my old iMac 2011 might be able to do that.
    I have not booted it up in over a year – so in the next day or 2 i will boot it up and
    see which version of FCPX is in it – i am pretty sure i also have 7to X on that –
    or the “other partition” which has FCP 7 on it.
    Also, if you have an old mac with an older OSX version, one should be able to
    install FCPX 10.0.3 or 10.3 if it cannot run 10.4.
  • Teo Camporeale
    September 11, 2020 at 11:40 pm
    Hi Patrick, thanks for your reply. Please let me know if you’re able to find anything out! I was trying to get to work on this project quickly, but after calling Apple, I found out my only route is to find someone with the old version still running– Lesson learned: ALWAYS make an XML back-up!! Thanks again, hope to hear back.
