Activity › Forums › Apple Final Cut Pro Legacy › HELP, Need to capture HDV-SD60P from JVC camera
  • HELP, Need to capture HDV-SD60P from JVC camera
    Posted by Mickie Shaw on November 9, 2007 at 6:42 pm
    Hello,
    This is a clarification to my previous post. The JVC GYHD100 has a rec. setting labled “HDV-SD60p”. According to the manuel it is recording “HDV format, shoots using a 480/60p signal.” I have a couple of tapes that are shot in this format and need to be edited
    My only question is does anyone know if FCP will edit this format? If not is there a work around?
    Thanks in advance!
    Paul Escandon replied 18 years, 10 months ago 2 Members · 4 Replies
  • Paul Escandon
    November 9, 2007 at 7:13 pm
    I briefly had a project that was shot in this format – I was able to edit it on Final Cut 5.1.4 but the only thing was at the time I could not capture it directly in Final Cut. I had to use a piece of software you can download from Apple called DVHSCap to be able to capture the HDV stream… and from there I was able to preserve the slow motion..
    Now, I’m not sure if FCP 6 has fixed this capture problem – but I definitely know that you can consider DVHSCap a workaround that works. Google DVHSCap and you should be able to find the proper download package from Apple. It’s free.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Mickie Shaw
    November 9, 2007 at 9:48 pm
    THank you, Thank you, Thank you!
    You are the first person that understands my problem. I have looked up the info you suggested and am going to try your work around. Thanks to you I also found some great info related to this problem at: https://karenoch.biblicalbear.com/?page_id=44 . She explains in detail how to download, install, and use the software you suggested. The software is only through Apple’s developer group and you have to be a member.
    May the video gods smile on all your projects!
  • Mickie Shaw
    November 10, 2007 at 3:50 am
    Your suggestion WORKS!!! Thank you again!!
    You are awesome!
  • Paul Escandon
    November 10, 2007 at 6:28 am
    Hey – very glad it worked for you! These forums are great aren’t they?
    Paul Escandon
    Oremus Productions
