Activity › Forums › Blackmagic Design › Help! Need to capture compressed from HD-SDI w/ Decklink HD
  • Help! Need to capture compressed from HD-SDI w/ Decklink HD
    Posted by Matt on June 7, 2005 at 11:49 pm
    Please help!! I need to get filming in the next couple days somehow. I have a hdr-fx1 which im outputting through the component analog output and
    into an aja hd10a which outputs hd-sdi into the decklink hd. The decklink hd is
    in a dual G5 with OSX 10.3.9 and FCP HD 4.5.
    I want to do chromakey work, but I do not have a raid setup for uncompressed
    video, so I need to capture directly to dvcprohd. I have read on many websites
    that it is possible to record to dvcprohd from the decklink hd sdi connection,
    but I have not been able to get this to work yet.
    When I called blackmagic design, they told me that it not possible at all, and
    that my only option is to get a raid setup and record uncompressed video. They
    also told me that to record anything i need to upgrade to the newest OSX and
    final cut, which I am prepared to do, but I would really like to avoid the raid
    setup and recording uncompressed hd. Anything you can tell me to shed some
    light on this would be greatly appreciated, as we’re already behind schedule and
    I seem to be stuck.
    Matt
    Kristian Lam replied 21 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 8, 2005 at 1:43 am
    You can certainly capture to DVCPRO HD on your G5 from a HD-SDI source.
    [Matt] “When I called blackmagic design, they told me that it not possible at all, and
    that my only option is to get a raid setup and record uncompressed video.”
    This information is not correct.
    Just choose the appropriate easy setup in Final Cut Pro HD. For example, “Blackmagic HDTV 1080psf 23.98 – DVCPRO HD”
