Activity Forums Apple Final Cut Pro Legacy HELP! Need FCP Advice ASAP!
  • HELP! Need FCP Advice ASAP!
    Posted by Marc Alcorn on May 23, 2005 at 4:20 pm
    Ok, I’ve never worked in the realm of film and 24FpS before so this is all new to me. I want to do this right the first time.
    I’ve got my machine set up with Final Cut Pro HD 4.5 on a G5 with a Decklink Extreme PCI-X card. DV deck is the Sony DSR-11. Capturing using Firewire.
    The footage I am using is on DVCam tapes…Footage originaly shot on HDCam at 23.98 but dumped down using 3:2 pulldown 29.97.
    I need to set up my capture and sequence presets so that when I send it off to do the on-line the EDL will reflect a 24p timeline and timecode. I really need help in setting this up right…
    Sequence Presets:
    Frame Size: 720×480 (NTSC DV 3:2)
    Pixel Aspect: NTSC – CCIR 601/ DV
    Field Dominance: Even or Odd Fields? (Do I need this if I
    Bryce Whiteside replied 21 years, 4 months ago 3 Members · 2 Replies
  • Matthew Brunn
    May 23, 2005 at 7:17 pm
    I’ve never edited 24p before or for that matter done a 3/2 pull down, but from tons of Cow reading the workflow for D 24p to DV is to get time-code window burns, edit, create edl in excel or some program for online at HD suite. I’m dealing with this for a friend who shot in HD and transfered to DV with no window time-code burn. It sounds like your going to try to match the time-code base of the original HD footage. I would search post in the HD forum too. If I remember, there are some issues with changing 24fps to 30 and back. Hope someone with more knowledge chimes in with more clear information.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Bryce Whiteside
    May 23, 2005 at 9:02 pm
    24p in Final Cut Pro HD and the DVX 100 By Graeme Nattress
    https://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html
    A Panasonic workflow but probably worth a read
    Workflow With Panasonic HD And Final Cut Pro HD – by Andrew Balis
    https://www.kenstone.net/fcp_homepage/fcp_homepage_index.html
    Be WARNED HighDef.com’s website has some JavaConsole action that brings Firefox browsers to a crawl, so use IE or perhaps Safari (untested)
    HighDef.com Information Library
    https://www.highdef.com/library/
    24P Primer (the 12 Easy Steps)
    https://www.highdef.com/library/24PPrimer.htm
    High Definition Fact Sheet (24p)
    https://www.highdef.com/library/HD24pFactSheet.htm
    HighDef FAQ
    https://www.highdef.org/library/faq.htm
    HTH,
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
