Activity › Forums › Adobe After Effects › Help! My mask won’t move!
  • Help! My mask won’t move!
    Posted by Scriptshaker on November 3, 2007 at 12:25 am
    Hi all. I have clip that requires a focused view of an actor on top of a distorted bg, all shot together. I’ve successfully masked the actor in AE and altered the bg. The only problem is the mask won’t move with him. I’ve set the in and out anchors and altered the mask to his shape on each, but it’s animating itself to those points, not moving with the actor. I know there’s a tutorial on this but I can’t find it. Could someone point me to it or provide what I know is a simple answer? Thanks much.
    Eric
    Steve Roberts replied 18 years, 11 months ago 2 Members · 3 Replies
  • Steve Roberts
    November 3, 2007 at 9:39 pm
    The mask only interpolates its shape between keyframes set by you.
    Now in AE, you can use *motion tracking* to track a point (or four), but those points can only be attached to the position of solids or effect points (say, the center of a lens flare). This does not help you, since you want to attach the trackers to mask vertices.
    I believe that there may be expressions to work with mask vertices, which may or may not help you. Try searching the COW for “mask vertex” and “expression”.
    But I think you want one of the tools by Imagineer systems like Mocha. But those cost money. (Note that the cheaper little Mocha for AE just tracks — it doesn’t actually mask. )
    If you don’t have that, I’m afraid you’ll have to rotoscope the talent, which means setting mask shape keyframes by hand. It’s boring work, but you can avoid a lot of wasted time by studying the talent’s motion carefully, and only placing leyframes when the motion of his shape changes direction, say from left-moving to down-moving. Let AE interpolate between those points. And if something (like a head) doesn’t change shape, mask it separately then just move the entire mask into position when necessary.
    No, it’s not automatic, but for that you gotta spend the bucks on a dedicated tool.
  • Scriptshaker
    November 3, 2007 at 10:51 pm
    Hi Steve,
    Thanks very much for the informative answer. I’d figured out as much right after I posted and just added enough keyframes to make the mask work, so I’m golden. But your solution info will come in very handy down the road. Thanks again.
    E
  • Steve Roberts
    November 4, 2007 at 7:34 pm
    Excellent.
    Roto is an art, and it doesn’t have to be a total pain. The worst case would be an amorphous flowing blob, or a dancer wearing a big flowing cape. But a lot of things have shapes whose motion can be predicted and masked with minimal keyframes and vertices once we learn to study the motion and draw efficiently.
