Activity Forums AJA Video Systems Help! My Kona’s gone crazy.
  • Help! My Kona’s gone crazy.
    Posted by Accomplice on November 29, 2005 at 4:51 pm
    It’s a Kona LH. Mac G5 dual. Brand new. 4GB RAM. Latest tiger. latest FCP.
    I was having problems with my video output. Certain graphics and titles created in my text tool would
    manifest artifact. A sentence I put ont the screen was white, However the period at the end was pink. I tried and tried to fix it but no matter what I do. It’s still pink. Other imported graphics had similar problems.
    Naturally, I decided to see if there were any software updates from Kona. I found 1.1.6 and installed
    it. Now my video ouput is gone. Not really good considering I need to master my project this afternoon.
    ANy help would be greatly appreciated.
    Walter Biscardi replied 20 years, 10 months ago 3 Members · 3 Replies
  • Jared Picune
    November 29, 2005 at 6:11 pm
    There are some issues with FCP and artifacts in 10bit. Is that what your project is setup in?? There are a few discussions about that in this forum. Hopefully that should give you the answers that you need. Good luck!!
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Accomplice
    November 29, 2005 at 6:34 pm
    I have switched to 8 bit and that seems to have solved my artifact problem. Does this mean that I am sacrificing video quality?
    I still have no video output though. If I do Show Current, it outputs the current frame no problem but still will not play video.
  • Walter Biscardi
    November 29, 2005 at 8:02 pm
    Are you using an Easy Setup?
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
