Activity Forums Blackmagic Design Help! Multibridge Extreme Downconversion not working
  • Help! Multibridge Extreme Downconversion not working
    Posted by Chris Borjis on March 23, 2006 at 6:30 pm
    I need to downconvert some HD footage.
    I have my HD Camcorder component outputs going to the inputs of the MultiBridge Extreme and I CAN capture
    into FCP 5 no problemo. I’ve got no output on the SDI output and I have tried turning off the G5 its connected to.
    Hardware downconversion is supposed to work with the mac off right?
    The objective is to downconvert this signal to SD SDI (digibeta)
    I have changed the settings in the control panel to the following:
    DECKLINK VIDEO & AUDIO CONNECTIONS
    output: all outputs active
    Input: Y, B-Y, R-Y Video & Analog XLR Audio
    HDTV UP/DOWN CONVERTER
    Output: (hardware) HD to HD/SD Anamorphic 16:9
    Input: 720P HD to SD Anamorphic 16:9
    Kristian Lam replied 20 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steven Bradford
    March 25, 2006 at 5:26 pm
    I don’t believe you can do this yet. We’ve been promised this downconversion ability since before we purchased our Multibridge in november 04, and we’re still waiting on it.
    Sometimes when you buy a product that seems too good to be true? You discover that it is.
    Steven Bradford
    FilmHD Program Chair
    Collins College
    Tempe Arizona
  • Kaspar Kallas
    March 26, 2006 at 5:41 am
    you should use the multibridge application not control panel to setup for converter usage
    -Kaspar
  • Chris Borjis
    March 27, 2006 at 5:53 pm
    multibridge application does not work. a box comes up saying to use
    the control panel lol.
    ok so the stand alone converter does not work yet. Nice. Its a damn good
    thing we were able to just downconvert when we digitized it or I’d be in a shit storm with my client.
    BlackMagic…..Please DO NOT tell people about available features if they are not available on product release. It makes YOUR customers (us) look bad which makes you look bad.
  • Kaspar Kallas
    March 27, 2006 at 6:11 pm
    you have to disconnet the PCIe cable then turn on your mac and connet the USB
    just bit tricky
    oh, but read the manual – it usually is pretty descriptive 😉
    still havent tested the the downconversion my self – been too busy
    -Kaspar
  • Kristian Lam
    March 28, 2006 at 12:57 am
    We currently do not support 20p down conversion on the Multibridge Extreme in hardware mode. If you want to do down conversion of a 720p 59.94 clip to NTSC, please use the software down conversion option.
    When the Multibridge Extreme is connected to the Mac via the PCIe cable, you change settings in the Blackmagic DeckLink Preferences. If the Multibridge Extreme is not connected to the PCIe card in your G5, it is operating in standalone mode. You’ll need to change the options using the Multibridge Utility and a USB connection to the Multibridge s required.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    March 28, 2006 at 5:07 pm
    [Kristian Lam] “We currently do not support 20p down conversion on the Multibridge Extreme in hardware mode. If you want to do down conversion of a 720p 59.94 clip to NTSC, please use the software down conversion option.”
    Do you mean 24P?
    Whats the real difference between software and hardware mode?
    I successfully captured 720P 59.94 through analog component HD from my JVC -HD100 and captured it in FCP as 10-bit uncompressed SD 16:9 anamorphic with the hardware mode option on.
    I wish it would simply have the option to go to tape as well. doesn’t really make sense that it can’t. Is that a future firmware update?
  • Kristian Lam
    March 29, 2006 at 2:57 am
    [Borjis] “Whats the real difference between software and hardware mode?”
    In software mode, the all outputs of the Multibridge Extreme gets down converted.
    In hardware mode, the following configuration is available:
    For example, when hardware down conversion is switched on:
    Channel A output: HD-SDI
    Channel B output: SD-SDI
    Component output: HD
    Composite Output: – (Composite signal does not have enough bandwidth for HD)
    When hardware down conversion is switched on with the “Enable Down Conversion on Analog Output” enabled:
    Component output: SD
    Composite output: SD
    At all times, the DVI-D output is in HD.
    regards
    Kristian Lam
    Blackmagic Design
