Activity Forums Avid Media Composer Help Moving Stills
  • Help Moving Stills
    Posted by Intake03 on October 24, 2005 at 10:56 pm
    Working on a project made up entirely of moving hi-res photos. Using After Effects to do all the moves, then render using AVID Uncompressed codec. My edit system is Adrenaline with settings on 1:1.
    On a majority of the photos, especially ones with detail, I have a terrible problem with the horizonal and vertical detail bouncing around.
    I never had this problem with my AVID Meridian system, but run across it frequently on the Adrenaline. Is this a problem with Adrenaline? Or is there something I can do to fix it?
    Michael Thomson replied 20 years, 11 months ago 3 Members · 2 Replies
  • Dan Archer
    October 25, 2005 at 8:35 pm
    In your avid are you in 8 or 10 bit mode. 8 bit gets really jigglly especially in hi res stills & gfx.
    If you can run your projesct in 10 bit. you should experience less anit-aliasing and more solid stills.
    If you are on a mac Adrinaline like me you have to wait ti ver 2 to get 10 bit…
  • Michael Thomson
    October 28, 2005 at 1:49 pm
    Try rendering your animations in AFX with deinterlace flicker, try 0.5 for softness.
