Activity › Forums › Apple Final Cut Pro Legacy › Help, Moving chapter markers, several en masse
  • Help, Moving chapter markers, several en masse
    Posted by Jim Branstetter on November 30, 2005 at 5:09 pm
    Hi All,
    Thanks in advance.
    My question is due to a last minute change by the client. I need to make an edit, cut out about 40 seconds of footage but I already have chapter markers set (in FCP).
    Is there any way to move the ALL the chapter markers after the edit over the length of the edit? There are a bunch of them as this this is a instructional DVD and this would save me having to move the one at a time.
    Thanks again
    Jim
    Arnie Schlissel replied 20 years, 10 months ago 3 Members · 2 Replies
  • Kevin Monahan
    November 30, 2005 at 9:39 pm
    Sounds like a feature request. No, there’s no way I know of that will do this.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Arnie Schlissel
    November 30, 2005 at 9:55 pm
    Short answer: no, you can’t move more than one marker at a time.
    However, you can simply plug a time code number, or even + or – a specific number of seconds & frames into a marker’s timecode field to move it. If you know that you’re removing 39;20, for example, all you have to do is hit shift+down arrow, then hit m, then tab down to the timecode field & type in -39;20 (or 39.20, or just 3920), and hit enter. Rinse, repeat till done.
    Arnie
    https://www.arniepix.com
