Activity › Forums › Adobe After Effects › help: motion paths lead to slow response time.
  • help: motion paths lead to slow response time.
    Posted by Joris Bergmans on January 17, 2009 at 12:35 pm
    I recently bought a new system and finally installed CS4 to test some things.
    Everything works fine and fast, but if I want to select and transform a layer in the viewer, there’s an unworkable delay in my actions, even if it’s an empty 1k composition with only a simple shape layer. This does not happen happen if I select or transform a layer in the layer panel.
    As this delay only happens when objects are animation, I found out the problem is solved when I switch off motion paths in the edit > preferences menu. In the past I had my motion paths always visible up to a minimum of 8 keyframes, and this rarely caused (notable) delays or problems.
    As my new system is a theoretically a huge step forward, I don’t understand how this can be.
    my new system is:
    -Vista Home premium 64-bit
    -Intel Core 2 quad CPU q9400 @ 2.66 Mhz 2.67 Ghz
    -8gb DDR2 ram
    -ATI Radeon 4850 1 gb
    -After Effects CS4
    my old system is:
    -XP home 32-bit
    -Intel Pentium IV FSB800 2.8 GHz
    -512 DDR400 ram
    -MSI Geforce FX*5600 TD 256 mb
    -After Effects CS2
    Any help is welcome!
    Thank you!
    Joris
    Joris Bergmans replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
