Activity Forums Adobe After Effects Help! More trouble rendering…
  • Help! More trouble rendering…
    Posted by Joe Feng on January 26, 2006 at 2:41 pm
    I’m getting the following error from AE7:
    After Effects: not enough memory to create memory for blurring
    (206954k requested, 196028k available)
    (37::103)
    I’ve already tried all the work arounds I could find from all the posts here and the error still pops up about 130 frames into the rendering…
    any help is appreciated!
    Joe Feng replied 20 years, 8 months ago 6,294 Members · 2 Replies
  • Joe Feng
    January 26, 2006 at 5:20 pm
    it is a rather large still, but i was able to render it last week. Now, after making some changes to the projects, (adding 3 more pics in the background, out of focus) it will no longer render. It seems to always stall on/around a certain spot…
  • Joe Feng
    January 27, 2006 at 3:19 pm
    Thanks for the info and help.
    I thought about blurring the pictures, however, they are being animated via the camera’s depth of field.
    After a few failed renders, I realized that the first successful render was done at a smaller comp size than 720*486. So I rendered the new file at 648*486, like last time, and had no problems. Not the ideal way to do things, but luckily, when imported into Avid, the difference is very minimal.
    But I will look into pre-rendering and using low-rez proxies.
