Activity Forums Maxon Cinema 4D HELP!!!! Mograph question ASAP
  • HELP!!!! Mograph question ASAP
    Posted by Julia K on November 10, 2008 at 4:23 pm
    I need help big time!
    I need to texture a mograph grid to be checkered pattern so every other square is black or white… how do i do that? Please help!!!!
    Brian Jones replied 17 years, 10 months ago 3 Members · 6 Replies
  • Brian Jones
    November 10, 2008 at 5:56 pm
    I assume you are cloning a plane or a box for the squares. Make two, put a white material on one, a black material on the other put both in your Cloner Object and set it to Iterate.
  • Julia K
    November 10, 2008 at 6:02 pm
    its more of checkered set, that is contained in a rectangle shape picture1.jpg
    when i do a projection its not aligning properly…
  • Johnnie Travis
    November 10, 2008 at 6:31 pm
    Julia, make sure your camera is set to either “front”, or “Parallel”. It looks like your camera is a “perspective” camera. I hope that helps.
    G5 DUAL 2.3,
    8GB RAM
    CALDIGIT S2VRHD
    AJA IO
    FCP 5.1.4
    10.4.10
  • Brian Jones
    November 10, 2008 at 7:06 pm
    Isn’t this what you’re after?
  • Julia K
    November 11, 2008 at 6:56 pm
    Thank you!!!! I’m sorry, i panicked… does anyone know of any ways to speed up render besides render farm?
  • Brian Jones
    November 12, 2008 at 4:38 am
    faster computer, lots of memory, try not to have more detail than you need, keep things like GI and Area light on a ‘I actually need this’ basis, there are ways to make it look close without using them. Read the manual it often has hints about settings that would be faster in some situations. But really 3D is complex enough there are always lots of ways to be quicker and without seeing your current scene it’s hard to know for sure what would help.
