Activity Forums Apple Final Cut Pro Legacy Help! Missing codec in FCP HD
  • Help! Missing codec in FCP HD
    Posted by Klawler on May 17, 2005 at 1:46 am
    I have a HD project with footage that was captured on a Kona 2 system. I was happily editing away until yesterday when I suddenly got an error message that states “Codec not found.” You may be using a compression type without the corresponding hardware card.” I thought I was using the DVC Pro HD codec which should be native to FCP HD (I’m editing on a dual 2.5 G5) and I still see the codec amongst my options but I can’t see any of my footage anymore and when I try to open it in quicktime it says “You may experience problems playing a video track in “name” because the compressor cannot be found.”
    I don’t know what caused this problem. I thought it was because I had upgraded to quicktime 7 but I uninstalled that and reinstalled Quicktime 6.5.2 but it didn’t fix it.
    Does anyone know what is wrong or more importantly how to fix it?
    Please help!
    Klawler replied 21 years, 3 months ago 2 Members · 2 Replies
  • David Bogie
    May 17, 2005 at 1:55 am
    Did you reinstall your Pro key for QT6+? QT7 may have changed the permissions for access to the advanced codecs since it was not pro enabled. Just a theory.
    Where did you get the codec? Can you reinstall it from your Kona CD?
    Worst case is something you could prepare for now: Start rounding up the original tapes.
    bogiesan
  • Klawler
    May 17, 2005 at 3:05 am
    I don’t have a Kona 2 card, the footage was captured onto a Kona 2 system and then copied onto my g-raid external hard drive. I really don’t want to have to re-digitize the footage and I don’t think it’s a problem with teh footage, I think its a system conflict.
