Activity › Forums › Adobe After Effects Expressions › Help me with expressions please
  • Help me with expressions please
    Posted by Maurrubio on April 18, 2006 at 2:56 pm
    Hi
    Im trying to figure how to use a expression like that:
    I have text layer with the number 1500, i want to count it to 1903.
    My question is how to make after effects link the numbers, for example, always when the number gets to 1509 it add a +1 on the next. 1510, when theres 1599 it add +1 to the next, 1600.
    I was sucessfull to make it work making a solid and apply the number effects, but i want to do it in a text layer. I hope you understand my question, sorry for the bad english.
    Mylenium replied 20 years, 5 months ago 2 Members · 1 Reply
  • Mylenium
    April 18, 2006 at 5:50 pm
    Not to state the obvious, but simple addition will do ;O).
    1500+Math.floor(time)
    will add one year for each second.
    1500+Math.floor(timeToFrames(time))
    will do the same, but at every frame. If you need the ultimate control add a slider expression control to your layer and try this:
    year_start=1500;
    year_end=1903;
    year_control=effect(“Slider Control”)(“Slider”);
    year_current=linear(year_control,0,100,year_start,year_end);
    [year_current]
    This will give you the same functionality like the Numbers effect – if you animate the slider from 0 to 100, the counter will follow accordingly, allowing you to add inbetween keys where needed.
    Mylenium
    [Pour Myl
