Activity Forums Apple Final Cut Pro Legacy Help me please. Problems with the multiclips timecode!!!
  • Help me please. Problems with the multiclips timecode!!!
    Posted by Emanuel1981 on June 29, 2007 at 10:28 am
    HY!!!
    I have a project in which there are 4 timelines containing 9 multiclips sequences edited. Each multiclip refer to 3 cameras.I use Final Cut Pro 5.0.4.
    When i finished the editing i cancelled the principal a/v clip because the audio quality was bad. Then i made batch capture and reconnect. So the principal clip is perfectly in sync with audio but the other two not. The other two are in sync between them.
    In the viewer the multiclips are ok but in the timeline not…
    Why this???
    HELP ME!!!
    901_david replied 19 years, 2 months ago 2 Members · 1 Reply
  • 901_david Create COW Profile Image
    901_david
    June 29, 2007 at 12:48 pm
    hmmmmm I have had a similar thing happen to me and someone with more experience may be able to shed some light on this, but I have made changes to a multiclip AKA change the sync of an angle or something similar to the main multiclip but since my multiclip was already in the timeline for somereason it wasnt refresed and changed I ended up having to drop it back in the time line again, luckily I hadn’t done any editing yet…..but the main problem was I found that one of the clips was out of sync and used the (either command shift or control shift I hav eto look it up every time) to change the sync of the angle and it would seeem to apply it to what was already in the timeline….this sounds very similar to whats going on in yours….I bet what would fix it (although I dont recommend it) is to simply delete and re drop the multiclips back into the timeline (you might even try it on another sequence) but I would love for someone with a ton of multiclip experience to shed some light onto this…..
