Activity Forums Apple Final Cut Pro Legacy Help me Move a Project to an External HD
  • Help me Move a Project to an External HD
    Posted by Jared Smith on July 30, 2009 at 12:24 am
    I tried to follow the directions of this post:
    https://discussions.apple.com/thread.jspa?messageID=9834911
    But I am having some issues. I have a FCP project going and it is taking up too much space on my internal HD. So I want to move everything from the folder I have of it on my desktop to my WD Passport. I tried to drag that entire folder to my external but it says “operation cannot be completed because an unexpected error occurred.” Any thoughts? I was able to drag each of the folders one by one, that is, all but the capture scratch folder…
    Help me out guys so I can free up some internal HD space.
    thanks
    jared
    Brian Walker replied 17 years, 1 month ago 4 Members · 6 Replies
  • Zane Barker
    July 30, 2009 at 3:19 am
    How is your external drive formated?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Jared Smith
    July 30, 2009 at 3:24 am
    well i am not 100%… i suppose it might be FAT32 but it is showing up on my mac desktop as the yellow icon… i have other things on there so i hate to reformat it but if that is the last ditch effort then so be it
  • Zane Barker
    July 30, 2009 at 3:32 am
    [Jared Smith] “FAT32”
    And that would be the problem.
    Fat32 has a 4GB file size limit. You will need to reformat the drive to MacOS Extended (doing so will erase what is on the drive) and then copy over your files again.
  • Jared Smith
    July 30, 2009 at 3:40 am
    is there any other thing i should check before doing that… i hate to erase the external drive’s contents and then find out that was not the problem… better yet, is there a way to verify if it is fat32 while it is plugged into my macbook?
  • Michael Gissing
    July 30, 2009 at 3:54 am
    Dragging folders is not a good way to move FCP files. Media Manager will copy the project and relink files. Just dragging will mean reconnecting – a tedious and unnecessary step.
  • Brian Walker
    July 30, 2009 at 5:18 am
    Zane is 100% correct about the 4 gig file limit with fat 32. You can select the icon on your desktop and hold the “command” key and “i” key at the same time to “get info” on your drive. AND do not move your project by dragging your folder to another hard drive… It will cause you problems. Just use the media manager to move or copy your project to anew location… Good Luck!
