Activity Forums Apple Final Cut Pro Legacy Help me make this effect.
  • Help me make this effect.
    Posted by Cjahrens87 on August 7, 2006 at 12:59 pm
    I want to make the effect where it appears a sort of red or yellow tint flashes over the top of the video. Similiar to a film flashe effect only in a red color and doesn’t really transition just adds effect to image. I hope this is a good enough description.
    chris
    Cjahrens87 replied 20 years, 1 month ago 2 Members · 2 Replies
  • Howie Chin
    August 7, 2006 at 1:07 pm
    One that I could think of on the go is…to have 2 layers of the same footage.
    Place some effects via color correction, tint, sepia to acheive the effect of red or yellow to your taste.
    Cut it up or rather chop it up…where the shortest one is a single frame…you should be able to get that flashy effect.
    You might wanna try to reduce the ocpacity to 50% – 60% so it doesn’t look too “horror like”– to tone it down 😉
    You could also try to shift the center of the footage that contains the red effect thing. So it sorta looks like a film went out of alignment…
    good luck!
    [howie]
    [howie]
  • Cjahrens87
    August 7, 2006 at 2:02 pm
    Great idea. I was approaching it the wron way. That will work.
    Thanks a bundle.
