Activity Forums VEGAS Pro help me get this project done, please
  • help me get this project done, please
    Posted by Al Kohout on July 6, 2006 at 11:17 pm
    Hello, I would appreciate your help on a few things with DVD Architect version 3.
    First is that, I have made a scene selection menu that has 27 links to it. Each link is a chapter. After that chapter plays I would like to have it go back to the
    Al Kohout replied 20 years, 1 month ago 2 Members · 2 Replies
  • Peter Wright
    July 7, 2006 at 1:16 am
    Chapters by definition are start points, not end points, so to achieve what you want you need to –
    1. Create the second menu by “Insert Submenu” rather than Scene selection
    2. On this submenu add the whole movie separately for each chapter, double click to open the timeline then drag the yellow arrows to make that instance start and end where you want. DVDA will realise that it is the same movie and not double/triple etc the space used.
    Ths way, when each chapter plays it will return to the submenu, or wherever you set End Action to go.
    For Photoshop, do a trial template, import to DVDA and check safe areas, then adjust as necessary.
    Audio levels cannot be adjusted in DVDA, so you need to set these when encoding, in Vegas or whatever you are using. If you are finding ac3’s are sounding quieter than you expect, create a custom template – I call mine “Maintain Levels” – with the following changes in settings (courtesy Edward Troxel) to the default ac3 template:
    Audio Service / Dialogue normalization: Set to -31dB
    Preprocessing / Line mode profile : set to None
    Preprocessing / RF mode profile : Set to none
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Al Kohout
    July 7, 2006 at 3:26 am
    Thanks..we were not using this method…I forgot about the sub menu routine
    Al
