Activity › Forums › Adobe After Effects › Help – LookAt not working with parented camera
  • Help – LookAt not working with parented camera
    Posted by Bonsak on August 29, 2005 at 2:59 pm
    Hi
    I want to rotate the camera around its Poin of iterest in a perfect circle.
    So i parent the camera to a Null located where the POI is,
    and then i rotate this null 360 deg. over a 45 second period.
    I have 9 layers that need to LookAt the camera,
    but it doesnt work when the camera is parented.
    It works fine when the camera is not parented.
    I also tried solving it with expressions but i cant figure out
    how to return the world position of the camera when its parented.
    Help please
    Regards
    Bonsak
    Bonsak replied 21 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 29, 2005 at 3:16 pm
    This should work:
    C = thisComp.layer(“Camera 1”);
    lookAt(C.toWorld([0,0,0]),position)
    But did you try just turning on Auto Orient > Orient Towards Camera?
    Dan
  • Bonsak
    August 29, 2005 at 4:42 pm
    Hi
    Thanks alot.
    Now i know how toWorld works 🙂
    I cant use Auto Orient because the 9 layers need to rotate/lookAt only around the y axis.
    Thanks again
    Regards
    Bonsak
