Activity Forums Apple OS X HELP: Iomega vs G-Raid Storage Devices
  • Tony! Hulette
    December 16, 2005 at 10:02 am
    Hey Eric,
    Between those two, G-RAID would be my choice, and its the choice ton’s of video editors and graphics pro’s. G-SATA would be even better, but you’ll need to add a SATA card to go with it. https://www.g-technology.com/Products/G-SATA.cfm
    If you want to save a little money, and gain some space, you could go with the OtherWorld Computing (OWC) 500GB Firewire RAID/Drives https://eshop.macsales.com/shop/firewire/1394/USB/EliteAL/RAID/ Maybe not quite as good as G-RAID, but a lot of bang for the buck. They’ve been making drives for a long time and have been a decent company to deal with.
    Also, I would consider Wiebetech’s solutions: https://www.wiebetech.com/home.php
    Having said all that, right now today, I”d go with the G-tech (raid or single drive. SATA, then FireWire). However, the OWC drives are an excellent cost effective option that I wouldn’t hesitate to use for backups, etc. G-Tech is probably overkill for backups unless you’re planning on working off of it regularly.
    Tony!
    P.S. G-Tech has a forum on the Cow, which says something about the company: https://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=176
