Activity › Forums › Apple Final Cut Pro Legacy › Help in the output
  • Help in the output
    Posted by Roy Schneider on May 31, 2006 at 2:42 am
    Hi All:
    I am at wits end. I editied a commercial on a 4:2:2 NTSC line. I am now trying to output to a DV cam tape on a Sony DSR-11. I nested the timeline to DV, and tried to output it to tape. Audio is coming through, but video is not. Please advise?
    Thanks for you help in saving my sanity.
    Roy
    Walter Biscardi replied 20 years, 4 months ago 3 Members · 4 Replies
  • Walter Biscardi
    May 31, 2006 at 2:52 am
    Check your Audio Video Settings. You’re probably still set up for Uncompressed SD.
    Just go to Easy Setup and set up for DV-NTSC.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Steve Eisen
    May 31, 2006 at 3:08 am
    Make sure DSR-11 input is set to DV.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Roy Schneider
    May 31, 2006 at 10:07 am
    Hi Guys:
    Thanks for the input. I set-up (in easy set-up) TO DV-NTSC, Nested DV-NTSC, and printed to tape. DSR-11 is set to DV input. same results however.
    Any other possibilities?
    Roy
  • Walter Biscardi
    May 31, 2006 at 11:50 am
    Check View > External video (or external View maybe?) and make sure it’s on “All frames” and not “Off”
    Try “Refresh A/V Devices”
    Make sure your nest is fully rendered.
